warning: Inconsistent pointwise non-ideal constraints found.
Do you know what this means? I get it when trying FSI in Comsol 4. It is non-destructive warning error, yet, it fills all the log file.
4 constraints are merged/removed.
Many thanks
13 Replies Last Post 2011/11/05 5:13 JST
Hello Danial Tz
Posted: 2 decades ago 2010/07/21 3:31 JST
It seems repeating in the Comsol 4.0a too. Anyone?
It gets annoying as all the log file is filled with these messages. The simulation runs normal though.
It seems repeating in the Comsol 4.0a too. Anyone? It gets annoying as all the log file is filled with these messages. The simulation runs normal though.
Posted: 2 decades ago 2010/08/11 0:43 JST
and this one:
Warning: New constraint force nodes detected: these are not stored !
Anyone?
and this one: Warning: New constraint force nodes detected: these are not stored ! Anyone?
Posted: 2 decades ago 2010/08/11 1:19 JST
I have been off comsol for a while now [ still have to move to 4.0] but I remember having these kind of warning when my constraint were not properly defined [ weak ideal non ideal.. ] with 3.5
So it is most probably the same things.. you need to clearly understand which type of constraint to use for a given problem .. and it is not easy .. [ to be honnest at the beginning I tried all possible combinations untile these warning messages disappeared.. again this come from my experience with 3.5...
hope this will help anyway
jf
Hi, I have been off comsol for a while now [ still have to move to 4.0] but I remember having these kind of warning when my constraint were not properly defined [ weak ideal non ideal.. ] with 3.5 So it is most probably the same things.. you need to clearly understand which type of constraint to use for a given problem .. and it is not easy .. [ to be honnest at the beginning I tried all possible combinations untile these warning messages disappeared.. again this come from my experience with 3.5... hope this will help anyway jf
Posted: 2 decades ago 2010/08/11 19:25 JST
jf
Hi Jean Francois,
Yes, you are correct for Comsol 3.5. The problem is that in Comsol 4 this is the error you get when using FSI module, and nothing else. It gives the error on the FSI boundaries.
[QUOTE] Hi, I have been off comsol for a while now [ still have to move to 4.0] but I remember having these kind of warning when my constraint were not properly defined [ weak ideal non ideal.. ] with 3.5 So it is most probably the same things.. you need to clearly understand which type of constraint to use for a given problem .. and it is not easy .. [ to be honnest at the beginning I tried all possible combinations untile these warning messages disappeared.. again this come from my experience with 3.5... hope this will help anyway jf [/QUOTE] Hi Jean Francois, Yes, you are correct for Comsol 3.5. The problem is that in Comsol 4 this is the error you get when using FSI module, and nothing else. It gives the error on the FSI boundaries.
Posted: 1 decade ago 2010/11/05 22:40 JST
It is also in Comsol 4.1. I cannot get rid of it. Anyone?
Comsol 4.0a, 4.1
Ubuntu 10.04.1
It is also in Comsol 4.1. I cannot get rid of it. Anyone? -- Comsol 4.0a, 4.1 Ubuntu 10.04.1
Posted: 1 decade ago 2010/11/05 23:28 JST
Do you combine pointwise and weak constraints?
Posted: 1 decade ago 2010/11/05 23:53 JST
Inconsistent pointwise unidirectional constraints found.
This is what it's saying in Comsol 4.1. I am just using a simple fsi boundary condition. Doing nothing special.
Comsol 4.0a
Ubuntu 10.04.14
4 constraints are merged/removed. Inconsistent pointwise unidirectional constraints found. This is what it's saying in Comsol 4.1. I am just using a simple fsi boundary condition. Doing nothing special. -- Comsol 4.0a Ubuntu 10.04.14
Posted: 1 decade ago 2010/11/06 23:04 JST
Well, it was just a try, because using weak constraints + pointwise constraints on the same variable and (adjacent) domain will result in problems during the discretisation. So COMSOL maybe removes these additional pointwise constraints, which produces your warning message.
Jean-Christophe Lavocat
Posted: 1 decade ago 2010/11/09 19:51 JST
I have the same one. It could be great to know where these duplicate constraint come from.
I personally got this message when using symmetries.
I have the same one. It could be great to know where these duplicate constraint come from. I personally got this message when using symmetries.
Posted: 1 decade ago 2011/10/11 10:42 JST
Did anybody find a solution to this thread? Even I get the warnings "inconsistent unidirectional constraints found". I can't get rid of them.
sirisha
Did anybody find a solution to this thread? Even I get the warnings "inconsistent unidirectional constraints found". I can't get rid of them. sirisha
Posted: 1 decade ago 2011/10/11 12:57 JST
and this one:
Anyone?
If this is still an issue, then Please see www.comsol.com/support/knowledgebase/1056/
I am still searching for an answer for the pointwise constraints.
sirisha
[QUOTE] and this one: Warning: New constraint force nodes detected: these are not stored ! Anyone? [/QUOTE] If this is still an issue, then Please see http://www.comsol.com/support/knowledgebase/1056/ I am still searching for an answer for the pointwise constraints. sirisha
Posted: 1 decade ago 2011/11/05 5:01 JST
I'm getting these warnings (FSI problem). Ultimately, my model fails.
Naturally, I suspect that the failure is related to this issue...
I'm getting these warnings (FSI problem). Ultimately, my model fails. Naturally, I suspect that the failure is related to this issue...
Posted: 1 decade ago 2011/11/05 5:13 JST
It could be but the chances are higher that its related to a too large mesh deformation issue, which often participate to trigger these warnings. Have you set the model to plot while solving so you see what is happening, often you need to track the mesh quality, as well as a few probe values in FSI issues
Hi It could be but the chances are higher that its related to a too large mesh deformation issue, which often participate to trigger these warnings. Have you set the model to plot while solving so you see what is happening, often you need to track the mesh quality, as well as a few probe values in FSI issues -- Good luck Ivar
