2 decades ago
2010/06/05 8:19 GMT-4
Ido not have comsol and matlab here from home, but shouldnt you index these too:
g4=geomcoerce('curve',carr);
s.objs={g4};
s.name={['CO' num2str(i)]};
s.tags={'g4'};
for me I read only 1 item, and if you go through all its only the "last one" remaining.
If you make a complex geoemtry with 2-3 or more items, COSMOL stores g1 g2 g3 g4 ... and the name list contains all names
check it out
Have fun Comsoling
s.objs={g4};
s.tags={'g4'};
check it out
Have fun Comsoling
2 decades ago
2010/06/05 12:48 GMT-4
I tried to index the following as:
g(i)=geomcoerce('curve',carr);
s.objs={g(i)};
s.tags={'g(i)'};
but COMSOL doesn't like that... I am not sure of a way to index variable names i.e.
g1...g500
Do you know how to do this?
s.objs={g(i)};
s.tags={'g(i)'};
g1...g500
2 decades ago
2010/06/05 12:59 GMT-4
not like that (I have no direct access to COMSOL from home), but really make a geometry from the GUI interface and save as a M file or just analyse your history.m file, and compare.
Then check that the naming is the same w.r.t. chr and ' '
2 decades ago
2010/06/07 8:46 GMT-4
I figured out how to create a geometry using a loop (while loop or for loop) in COMSOL/MATLAB... It finally occurred to me what I had to do... I guess I am a little out of practice! Thank you for your help!
Markthomas
Markthomas
2011/03/25 11:29 GMT-4
I figured out how to create a geometry using a loop ...
So let us know, please!
[QUOTE]
[/QUOTE]
2011/04/18 9:42 GMT-4
1) I have an arc that form my 2-D geometry. I also have an array of straight lines(y=constant) that cut my arc splitting into multiple arcs.
2) I need to move my multiple arcs to different positions.
3) So i select the arc to be moved.
4) Now I need to access the index of the array of straight line that is nearest to this arc.
5) So, I need to loop through the existing array and extract the y-coordinate of this straight line from the array.
6) Then retrieve the min y-position of the arc selected for moving.
7) Use if condition to check if y of line exceeds y of the appropriate arc.
8) Based on the above comparison, decide where to place my arc.
9) The displacement through which I take the arc will have the array index that is to be retrieved in 4.
I do not expect an exact solution to the problem but would be glad even if I can get hints on
a) how to access the index of an array of geometric object.
b) how to write if condition
c) how to write for loop
Note: I am flexible to choose between 3.5 and 4.1 or even integrating matlab with comsol if necessary though I have never tried it before.
