droplet modelling
can anyone tell me the correct procedure for modelling a water drop on wetted surface.... i used 2 phase flow level set and phase field... but its not working.. i jst want to make dat drop on the horizontal wetted wall. plz reply....
2 Replies Last Post 2017/04/18 14:48 GMT-4
Hello Krishna Raj G G
Posted: 9 years ago 2016/07/24 10:31 GMT-4
Even I am in need of this.Can anyone please reply?
Hi Even I am in need of this.Can anyone please reply?
Posted: 9 years ago 2017/04/18 14:48 GMT-4
It depends on what you want to get from your simulation.
1) If the drop is going to move relatively fast or displace significantly from its initial position, I'd go with one of the "level set" or "phase field" methods.
2) If it is resting on a substrate and/or experiencing a relatively small deformation and displacement (i.e evaporation, condensation,...), I'd select the "laminar flow moving mesh" as it treats the interface more accurately.
Amin,
Hi It depends on what you want to get from your simulation. 1) If the drop is going to move relatively fast or displace significantly from its initial position, I'd go with one of the "level set" or "phase field" methods. 2) If it is resting on a substrate and/or experiencing a relatively small deformation and displacement (i.e evaporation, condensation,...), I'd select the "laminar flow moving mesh" as it treats the interface more accurately. Amin,
