Hello Nima Izadi
2010/08/27 4:49 JST
Nima,
I am not answering your questions but just listing some of the counter-intuitive things that I have seen so far:
I am almost new in using COMSOL so may be it is me that I do not have much experience properly using it.
1- I applied an initial strain to a 2D slab (located in xy plane) made of an isotropic material. The initial strain was in x direction. It correctly solves for the deformation, which is the same as the analytical one i.e. delta= P*L/A/E. However, the numerical solution for the stress is completely wrong (400 Pa analytical vs. 1e-11 numerical) which is odd. In addition the stress is not uniform and changes significantly across the area that the strain was applied despite a uniform strain.
2- Then I deactivated the initial strain and activated the stress (the stress that I calculated analytically but did not get numerically). In this case, amazingly when I added a positive stress (outward) the slab underwent compression and when I applied a compressive stress the slab stretched !! (although the magnitudes of the deformations were correct).
3- Apparently, the mode of Plane-Stress or Plane-Strain does not affect the above observations.
4- When I switched from isotropic material to a hyperelastic material with large deformation option (or even w/o it) nothing happened as if there were no initial strain or stress.
Manuel
Nima,
Manuel
2010/08/27 16:07 JST
I have some issues when following your model:
1) you apply a force and not a torque on the cenral one
2) for me you cannot simplify the initial stress only as a X and Y stress components, because the stress tensor should change with the correct relation between each other
3) you have an antisymmetric boundary that I do not catch why to
4) your mesh is too coarse in the thickness, you should use either a surface shell, or use the advanced feature and expand the Z direction by a factor of 20-50 to get more elements in the Z direction (or use the sweep mesh)
Try to study the stress distribution in your system when you apply the different stress values, that would probably give you some clues of what is going wrong (not that the von mises hardly changes (combination of all), but the different stress components do change in different ways. But take care with the automatic plot rescaling when you change the parameter setting, check also carefully te absolute values, not only the rainbow = % relative values
