How to define a new liquid (aqueous KCL solution)
Hey
I want to study the flow of aqueous solution of KCL (.00018 Molar) through a micro sized channel but how to define this KCL solution with its parameters like viscosity, density, conductivity etc
2 Replies Last Post 2010/06/21 18:31 JST
Posted: 2 decades ago 2010/06/21 5:32 JST
I have modelled and cross-validated many systems using KCL.
I approximate the viscosity and density to water, the conductivity can be calculated using the equivalent conductivity equation.
I provide the parameters for these in the sub-domain settings on a ad-hoc basis without worrying about creating a new material in the material library.
Tom
Hi, I have modelled and cross-validated many systems using KCL. I approximate the viscosity and density to water, the conductivity can be calculated using the equivalent conductivity equation. I provide the parameters for these in the sub-domain settings on a ad-hoc basis without worrying about creating a new material in the material library. Regards, Tom
Posted: 2 decades ago 2010/06/21 18:31 JST
Studying the flow of aqueous solution means two things: Navier-Stocks equation for fluid properties and Poisson+Nernst-Planck equation for the electrochemical behavior of your fluid.
Then you will find all the parameters that you are looking for: viscosity, density, conductivity...
Hi, Studying the flow of aqueous solution means two things: Navier-Stocks equation for fluid properties and Poisson+Nernst-Planck equation for the electrochemical behavior of your fluid. Then you will find all the parameters that you are looking for: viscosity, density, conductivity... Good luck
