Solve hydro-gel swelling behaviour with comsol!!!!
Hi all,
I want to solve a problem of swelling and relaxation of hydrogel with comsol.
Is it possible to show swelling behave of hydrogel using comsol?
Cheers!!
Rajesh
5 Replies Last Post 2014/09/26 21:10 JST
Hello Rajesh Kumar
Posted: 1 decade ago 2012/06/05 0:44 JST
I also want to do such kind of thing. Have you make any progress? can you share with me!!
Posted: 1 decade ago 2013/05/14 10:52 JST
I am looking for the same stuff, can you help if you solve this problem??
Posted: 1 decade ago 2013/05/14 18:47 JST
Same problem here. I started to combine a diffusion physics with a solid mechanics physics(viscoelasticity) but it seems harder then I thought. If you have something concret in thisdirection contact me.
Amnani Binti Shamjuddin
Posted: 1 decade ago 2014/09/24 4:15 JST
Same goes here... I also need to solve this kind of problem.. Now, it is nearly end of 2014.. Anyone who can share any of their contribution?
I found a PhD thesis (Modelling of Multicomponent Diffusion and Swelling in Protein Gels) by Kang Lu (2011). The author used PDE based in COMSOL. The detail steps of his work in COMSOL had not published in the thesis.
Same goes here... I also need to solve this kind of problem.. Now, it is nearly end of 2014.. Anyone who can share any of their contribution? I found a PhD thesis (Modelling of Multicomponent Diffusion and Swelling in Protein Gels) by Kang Lu (2011). The author used PDE based in COMSOL. The detail steps of his work in COMSOL had not published in the thesis.
Posted: 1 decade ago 2014/09/26 21:10 JST
The thesis provided above has a good amount of details on the COMSOL implementation of the hydrogel material model. Here is another online document that also provides good details on hydrogel material implementation: www.cimne.com/cm-master/doc/thesis/masterthesisburelamelie.pdf . Both documents use COMSOL 3.5 it seems but I see no reason why the latest COMSOL version would not work.
Nagi Elabbasi
Veryst Engineering
The thesis provided above has a good amount of details on the COMSOL implementation of the hydrogel material model. Here is another online document that also provides good details on hydrogel material implementation: http://www.cimne.com/cm-master/doc/thesis/masterthesisburelamelie.pdf . Both documents use COMSOL 3.5 it seems but I see no reason why the latest COMSOL version would not work. Nagi Elabbasi Veryst Engineering
