Boundary Integration factor of 1000 different
Posted 2009/08/31 15:59 GMT-4 1 Reply
If I perform a boundary integration through the PostProcessing > Boundary Integration menu on an outlet velocity, v, I get -2.428152e-9 [L/s]. Then if I then goto Options > Integration Couplings > Boundary Variables and enter VolFlow as the Name, v as the Expression and 4 as the Integration Order. Then in Global Expressions I create a variable called VolF which equals VolFlow.
I run the simulation and perform a boundary integration using the first method the result is -2.428152e-9 [L/s]. If I then look at the value of VolFlow from the PostProcessing > Global Variables VolF = -2.428152e-12
Why is there a factor of 1000 difference?
Tom
Tom
1 Reply Last Post 2009/08/31 16:09 GMT-4
