2D Heat flux
Posted 2010/06/15 11:28 GMT-4 Heat Transfer & Phase Change Version 4.0a 12 Replies
I have a 2D model with a boundary condition of 2D heat flux on a wall. But instead of asking for heat flux in W/m for the 2D solution, the input lists W/m^2, as in a 3D solution. This implies that COMSOL is assuming something about the depth of the 2D model. Is it just 1m?
YES you are right, COMSOL is alwaye working in 3D, when you select 2D or 2D axi, or even 1D COMSOL assumes a default depth (in 2D its ussually 1[m] it's defined on the subdomain/main physics page, ususally named "thickss", it is to be understood as the "Z" direction as 2D is by defult x-y.
In 2D axi you need to multiply surfaces by 2*pi*r to get to volumes (for integration), its the "loop length" and must often be used for BC definition too, to get the units compliant.
In 1D its a area that is assumed (in Y and Z).
That is why one should always check the units (but some functions do not correctl transfer units, such as integration coupling variables so these might "flag red" even if they are correct. this applies to 3.5, its better in V4, but there are still a few holes in the current V4 too. It's quite a job to get all hese cases correct, but its very useful for us to check what we are doing, no ?
Have fun Comsoling
Thanks for the help. I am using 2D, but not axisymmetric. I suppose the thickness is then 1m, but it is not a variable in the subdomain physics section. It is a setting in some structural mechanics models, but not heat transfer or fluid flow. The equations are being solved in 2D, but it still confuses me why the boundary condition for heat flux seems to be 3D, ie - W/m^2 instead of W/m. Once my solution runs, the total heat input does not seem to correlate with a 1m depth though.
you are right I'm s used to structural that's what comes up first ;)
Which version are you running ?
ivar
Version 3.5. Thanks.
then if you go into the "Physics - Equations - Boundary Settings - Variable tab", at the bottom of the list there are a few constants, I believe it's these, but I'm not 100% sure, you should check with the doc and COMSOL support. But it seems natural to use 1[m] depth as default
You must have a 2D surface defines, and selected the appropriate physics on a boundary, otherwis COMSOL is not defining any variables, if not needed
U_htgh, L htgh, dVolbnd_htgh = 1
Infact in V4 you cannot even see these variables, neither any "depth info", this could be more explicit, I agree, could be worth to send a suggestion to COMSOL
Have fun Comsoling
Unfortunately I do not see any constants there. I will check the documentation a little more then. Thanks for the help.
Do not forget to select the correct physics and settigns then APPLY to have comsol updates the required variables
I have updated my previous post
"htgh" is the general heat transfer and it looks like L_htgh refers to the convection length scale. Plus, I am using the non-isothermal module and those are not available.
I am experimenting with simpler models to find an appropriate comparison. However, you are right, it seems that it could be made easier.
v3.5 see the htug.pdf p63, for V4 its p23 the depths re there, and in some cases its by default 1cm and not 1m !
I am trying to change the default cross-sectional area in a 1D time-dependent heat transfer problem. The cross-sectional area drastically changes the time scale. I have a cross-sectional area that is not a neat unit square of any standard unit.
I have looked at all these posts and searched the manuals, and I cannot figure out how to change this (or the depth assumed in a 2D simulation). How can I change these values?
Thanks!
