Consumption of species
Posted 2015/03/14 8:47 GMT-4 Chemical Reaction Engineering Version 5.2 8 Replies
I have a question because I'm not quite sure how to model it. I have a reactor (square) which contains a chemical component A. A can react to B with the help of a catalyst. I want to simulate the consumption on the right side of the reactor (lets say A can diffuse in the whole reactor) with respect to the generation of B.
I'm not quite sure which modules to use. I tried with the diluted species (and maybe surface reaction modul?); But I don't know how I can set this up with the diluted species module.
Thanks for you help. I appreciate it.
regards Mika
dcA/dt = DA*nabla^2 cA + R
R = -k*cA
or whatever reaction term that is pertinent to your reaction.
br
Lasse
thank you for your fast reply.
But I still have an understanding problem. i know that I can add a reaction term for my diffusion but how does COMSOL know that the consumption only takes place at a certain domain? Can I implement this in any way?
Thanks for your help
Lasse
I did a mistake in my last answer, I wanted to say boundary instead of domain, sorry.
I know that I have to select the domain and that's where I have trouble because my reactor is a square. Is there a possibility to select a boundary where the reaction takes place? Or do I have to create a square reactor with four seperate lines which form a square and then select one domain?
Thanks for your help.
If a reaction takes place on the boundary, then it is not written as a reaction term in the diffusion equation, but as a flux boundary condition.
Inward flux: -k*cA
but now notice that the units of k, the reaction rate constant, is m/s in order to have flux in mol/(m^2*s).
BR
Lasse
So if I understood it correctly. For the species B which gets created at the boundary I can just do the same with an inward flux, right?
the equations are in the attached file.
Thanks!
