Nagi Elabbasi
Facebook Reality Labs
2015/03/24 1:57 JST
I don’t see anything wrong with the procedure. If you post the model you’re likely to get someone to look at it.
2015/03/24 16:58 JST
Thanks for your answer,
I have added the simulate file in this post ;)
Furthermore I customize the model, insertion of a titanium ball.
I noticed that the titanium ball strongly deformed. It would be very nice if you could view the model and can give me tips.
Thank you for your help,
cya Thomas
P.S.: The displacement at 600mN we actually expect at 40 mN
cya Thomas
2015/03/24 22:46 JST
I didn't see any deformation of the ball, but a very large deformation of your thin blade, so I would suggest that you consider the non-linear geometry mode for such large deflexions, and compare your results.
Another point is do you have a static X body load or a "follower" ball-section-normal load, for these deformations that has some importance
2015/03/24 22:57 JST
Hello Ivar,
thanks for your advice. Can you please tell me where I can adjust non-linear geometry?
The model is actually a neodymium magnet ball, fixture on a leaf spring and a magnetic forces (Y-axis) provides the deflected.
Thanks für your help, cya Thomas
Hello Ivar,
2015/03/27 19:24 JST
I noticed that the ball is very strongly deformed at very low forces (F=2 x 2N) and for the ball i used Structural steel as material (Build-In).
In the picture you can see the big deformation, can somebody say with what I'm doing wrong?
Best regards
Thomas
Best regards
Thomas
2015/03/30 17:29 JST
Hello again,
it would be great if someone can give me a hint again, because my ball of steel are deform very strong at even 2N force.
This may not agree with the reality ;)
Thank you and best regards
Thomas
Hello again,
Thomas
2015/04/01 17:12 JST
Hello again,
sorry for pushing this contribution again. Unfortunately, I'm stuck with my Simulatuion, the deformation of the steel ball is still too big for my used force (see picture in the previous post).
I would appreciate any help or suggestion,
thanks and cya Thomas
Hello again,
2015/04/02 4:19 JST
Looks funny indeed, but your stress is also very high !
at least 100-1000x above yeld stress so I suspect a unit isue in your BC/Domain load there.
And you might have turned on "automatic" scaling ? that gives different scales for different directions
