Simple Java Programme does not compile in V50
Posted 2015/03/24 8:05 GMT-4 API Version 5.0 2 Replies
Hallo,
the very simple java programme below works in version 4.4 of Comsol but not with version 5.0.
There are no error messages, but the class-file is not generated.
I run (on Linux):
comsol compile test.java
Did anybody run into the same problem and found a solution?
Thanks in advance.
Regards
Jens
import java.io.*;
import com.comsol.model.*;
import com.comsol.model.util.*;
public class test{
public static void main(String[] args) throws Exception {
run();
public static Model run() throws Exception{
Model model = ModelUtil.create("Model");
model.param().set("Laenge","4.6[m]");
return model;
I run (on Linux):
Thanks in advance.
Regards
Jens
import java.io.*;
public class test{
run();
return model;
2 Replies Last Post 2015/03/25 3:18 GMT-4
