Phase Angle
Is there a way to plot a point solution value with respect to the solution phase angle?
I am using COMSOL v3.5a Acoustics Module (Time-Harmonic Analysis; stationary solution)
-Jon
1 Reply Last Post 2010/06/26 23:06 JST
Posted: 2 decades ago 2010/06/26 23:06 JST
Yes I'm missing also some BODE type plots to get phase and ampliude out. ut now, I believe you can still idcentify the phasor name (in the worst case try to locate it in the doc or in the "Physics - Equation Settings ... sub tabs" and then do a plot where you replace the X value by an expression (plots options) and put in your phasor name,. for me this should work (havent tried though)
Pls report back if its OK, could be usefull for others too
Have fun Comsoling
Hi Yes I'm missing also some BODE type plots to get phase and ampliude out. ut now, I believe you can still idcentify the phasor name (in the worst case try to locate it in the doc or in the "Physics - Equation Settings ... sub tabs" and then do a plot where you replace the X value by an expression (plots options) and put in your phasor name,. for me this should work (havent tried though) Pls report back if its OK, could be usefull for others too Have fun Comsoling Ivar
