Coupling between free and porous media flow-impossible to solve in 3D?
Hi every body,
I have a model simple including a free domain( a block) and a porous media(a cylinder). The flow is described by the Navier stock equation in free region and the brinkman equations in the porous media. I tried all solver , only solvers indirect and the preconditioner "complete U"could be run, but it was not converged. So, it is impossible to solve this simple coupling?
I attatch the file .mph below if someone want to see the problem
1 Reply Last Post 2010/06/27 9:42 JST
Posted: 2 decades ago 2010/06/27 9:42 JST
Hi, I tried to run your model, but it said it was in a version compiled before 3.5a, so it cannot be opened in 4.0
You could try upgrading to a more recent COMSOL to see if that helps?
More generally, try running at a lower Reynold's number and see if you can get that to converge. If so, then you could use a continuation technique where you slowly increase the Re to what you need, using the previous answer as initial guess to the next.
Regards, John
Hi, I tried to run your model, but it said it was in a version compiled before 3.5a, so it cannot be opened in 4.0 You could try upgrading to a more recent COMSOL to see if that helps? More generally, try running at a lower Reynold's number and see if you can get that to converge. If so, then you could use a continuation technique where you slowly increase the Re to what you need, using the previous answer as initial guess to the next. Regards, John
