Modelling admittance in Comsol V4
I have a model which uses conductivity and permittivity as the parameters for a dielectric material. This dielectric is placed between a HV supply (modelled as terminal and ground), using 'electric currents' mode. In the previous version, v3.5a using 'quasi-statics' mode, it was the case of evaluating the admittance (then converting to resistance and capacitance). v4 doesn't seem as simple, I've tried 'derived values, global evaluation' - I can get a resistance, but no capacitance.
Has anyone managed to do something similar in v4?
Regards, David.
5 Replies Last Post 2011/07/12 20:14 JST
Posted: 1 decade ago 2010/07/09 21:27 JST
I've found the problem.
When v3.5a frequency dependent models are brought across into v4 the freqency domain needs to be re-activated in advanced settings. Once this is done the admittance becomes available as a variable.
I've found the problem. When v3.5a frequency dependent models are brought across into v4 the freqency domain needs to be re-activated in advanced settings. Once this is done the admittance becomes available as a variable.
Posted: 1 decade ago 2011/07/04 5:07 JST
Dear David,
I am also trying to simulate impedance for a parallel plate capacitor with water as a dielectric. I do not see a change in the value of impedance/admittance with frequency. Can you shed some light on this. Do we need to define permittivity and conductivity of the solution as a function of frequency. If you can share your model which can give a fair idea about the variables defined and the boundary conditions, it will be of great help. I have tried simulating in both version 4.0 and 3.5, so model in any of the versions would be of help.
Thanks in anticipation
Nidhi
Dear David, I am also trying to simulate impedance for a parallel plate capacitor with water as a dielectric. I do not see a change in the value of impedance/admittance with frequency. Can you shed some light on this. Do we need to define permittivity and conductivity of the solution as a function of frequency. If you can share your model which can give a fair idea about the variables defined and the boundary conditions, it will be of great help. I have tried simulating in both version 4.0 and 3.5, so model in any of the versions would be of help. Thanks in anticipation Nidhi
Posted: 1 decade ago 2011/07/06 21:17 JST
Dear Nidhi,
Thanks for your interest in this work.
You should see a change in admittance (capacitive component) with changes in frequency without specifying frequency dependent material properties as Xc=1/(2*pi*f*C), where C=ep*A/d.
The model should be set-up as follows:
- Electric currents application mode
- Frequency domain study
- The energised boundary should be a 'terminal'
- The grounded boundary is of course 'ground'
- The open boundaries are 'electric insulation'
I have attached a basic model for reference.
Meshing is critical and you may need to use the 'adaptive mesh refinement' tools for an accurate solution.
I hope this had been of assistance.
David.
Dear Nidhi, Thanks for your interest in this work. You should see a change in admittance (capacitive component) with changes in frequency without specifying frequency dependent material properties as Xc=1/(2*pi*f*C), where C=ep*A/d. The model should be set-up as follows: - Electric currents application mode - Frequency domain study - The energised boundary should be a 'terminal' - The grounded boundary is of course 'ground' - The open boundaries are 'electric insulation' I have attached a basic model for reference. Meshing is critical and you may need to use the 'adaptive mesh refinement' tools for an accurate solution. I hope this had been of assistance. Regards, David.
Posted: 1 decade ago 2011/07/07 18:02 JST
Thanks David for sending the information across. Can you please let me know which version of comsol you have used for the model. I have not been able to open the file in Comsol 4.0, it says that an advanced version has been used to make the model. If possible can you send a 4.0 compatible version of the model?
Nidhi
Thanks David for sending the information across. Can you please let me know which version of comsol you have used for the model. I have not been able to open the file in Comsol 4.0, it says that an advanced version has been used to make the model. If possible can you send a 4.0 compatible version of the model? Regards, Nidhi
Posted: 1 decade ago 2011/07/12 20:14 JST
Hi Nidhi,
I am using COMSOL 4.1 and do not have any older versions installed on my computer.
Have a read of the example (tunable capacitor) in the COMSOL model library as it will help when setting up your model.
David.
Hi Nidhi, I am using COMSOL 4.1 and do not have any older versions installed on my computer. Have a read of the example (tunable capacitor) in the COMSOL model library as it will help when setting up your model. Regards, David.
