Small changes in size introduce a "divergence cleaning" error
Posted 2015/04/03 23:53 JST Low-Frequency Electromagnetics, Geometry Version 5.0 1 Reply
I'm trying to model magnetic field around a stationary uniform current density. Check the attached file.
The model is really simple: two concentric cylinders both with height "len" and the bigger one has radius "len" and smaller one has radius "len/10".
Now the bizarre thing is that when the parameter "len" is about 300 nm or higher, then everything works well. When len is less than 200 nm, I always get the "Divergence cleaning failed for linear system." error. When len is between 200 and 300, it sometimes gives the error and sometimes it doesn't.
Tweaking the external current density and conductivity didn't change the behavior.
What could cause this error? How could I fix it? I need to do similar simulations to this in length scales of about ~5 nm.
1 Reply Last Post 2015/04/05 1:23 JST
