Regarding mems switch movement
HEllo all!!
I am new to COMSOL Multiphysics.I am given a task to design a phase shifter using mems switch.But,i am unable to design a mems switch in comsol.i.e,i am able to draw the Geometry and could not make the cantilever move as i wanted,when a field is applied.Can any one please design a MEMS switch with cantilever(movement at one end-with other end fixed) in comsol and upload the .mph file here....
Thankyou all...
PLease help me out with this.This is my project.Urgent....
9 Replies Last Post 2012/10/05 19:57 JST
Posted: 2 decades ago 2010/07/01 14:36 JST
please help me out in its design.....I am not able to make Short circuit and Open circuit between two conductors --by applying a voltage to the electrode/actuator....
Posted: 2 decades ago 2010/07/09 16:03 JST
can any one please upload their .mph file where if voltage applied, there should be some short circuit and open circuit configuration.
Thankyou
can any one please upload their .mph file where if voltage applied, there should be some short circuit and open circuit configuration. Thankyou
Posted: 2 decades ago 2010/07/17 19:51 JST
can any one please upload their already done RF mems switch design?
Posted: 1 decade ago 2012/07/26 17:57 JST
hi i m also solving that same module my project work is Phase shifter based MEMS switch. could you please help me?
Posted: 1 decade ago 2012/10/05 13:54 JST
I am working on RF MEMS switch ( Capacitive switch) . I got a problem while meshing the structure . After computing , I am getting an error.
ERROR : No mesh on domains 4 5 18 19 in geometry 1, mesh case 0.
Even when i mesh all the domains, same error message is displayed . I am pretty new to comsol . I am using 4.2 version.
Is there any particular way of finding a suitable mesh for a particular structure? can we use the same mesh for any type of structure? where can i find some material on meshing ?
I am working on RF MEMS switch ( Capacitive switch) . I got a problem while meshing the structure . After computing , I am getting an error. ERROR : No mesh on domains 4 5 18 19 in geometry 1, mesh case 0. Even when i mesh all the domains, same error message is displayed . I am pretty new to comsol . I am using 4.2 version. Is there any particular way of finding a suitable mesh for a particular structure? can we use the same mesh for any type of structure? where can i find some material on meshing ?
Posted: 1 decade ago 2012/10/05 14:33 JST
meshing is almost an art ,), but generally the default physics induced mesh by COMSOL is very good and perfect for a starting point.
What you must ensure is that your last mesh node refers to all "remaining" and not to just a few domains, else you might easily, as you have managed, forget a few domains, and your model is not fully meshed, hence the error
Hi meshing is almost an art ,), but generally the default physics induced mesh by COMSOL is very good and perfect for a starting point. What you must ensure is that your last mesh node refers to all "remaining" and not to just a few domains, else you might easily, as you have managed, forget a few domains, and your model is not fully meshed, hence the error -- Good luck Ivar
Posted: 1 decade ago 2012/10/05 16:11 JST
Thanks Ivar ,
will you please suggest me how to learn basics of meshing?
Thanks Ivar , will you please suggest me how to learn basics of meshing?
Posted: 1 decade ago 2012/10/05 19:57 JST
Re-read the doc on the meshing functions, follow the video's on the amin Web site, take a meshing course by COMSOL, come to the conference and take a quick course there, and try it out model after model, it's mainly the exercising gives you the skills, as often ;)
Not to forget try out models exchanged here on the Forum, help us to help each others.
You could also try a search on the FORUM, meshing issues come up quite often
Hi Re-read the doc on the meshing functions, follow the video's on the amin Web site, take a meshing course by COMSOL, come to the conference and take a quick course there, and try it out model after model, it's mainly the exercising gives you the skills, as often ;) Not to forget try out models exchanged here on the Forum, help us to help each others. You could also try a search on the FORUM, meshing issues come up quite often -- Good luck Ivar
