FSI and Turbulent Flow
Posted 2010/06/29 10:38 GMT-4 Computational Fluid Dynamics (CFD) Version 3.5a 3 Replies
I am trying to use the turbulent k-epsilon model in the chemical engineering module with fluid-Structure Interactions (FSI). Since my problem is an FSI case with turbulent fluid flow, I must use turbulent model with the FSI feature. While trying to solve the problem, It gives a message
"Error: 6250
Failed to evaluate variable Jacobian.
- Variable: T_x_chns2
- Geometry: 1
- Boundaries: 16,17,42,47"
Kindly guide me if I am not selecting the modules properly or not coupling it propoerly. Kindly suggest what should I do. The file is attached for reference.
Thank you
"Error: 6250
- Geometry: 1
Thank you
3 Replies Last Post 2011/05/05 10:54 GMT-4
