                                2 decades ago
                                2010/07/07 8:44 GMT-4
                                                    Rectangular pulse should be difficult, if not impossible. Try checking if they have heaviside functions in Comsol. But even then, I am unsure if you would be able to have high enough sampling to capture that jump discontinuity. I would rather suggest you to think along a ramp pulse which has the added advantage of being physically possible.
Providing sinusoidal signal is easy. Use sin(f0*t) by specifying the value of frequency f0. I would also suggest you to search this topic in forum's archive. There should be something interesting.
All the best.
All the best.
                                2 decades ago
                                2010/10/12 7:43 GMT-4
                                                    Hi!
If I understood you correctly, you can define square pulse of duration 'pulse_width' and pulse period of 'pulse_period' just simply by the following variable
pulseON=(mod(t,pulse_period)<=pulse_width)
Then you just multiply your time-dependent variable with pulseON.
flow_pulsed = flow * pulseON
let's say
pulse_width = 1 s
pulse_period = 5 s
then for
t = 0.5 s pulseON = 1
t = 1        pulseON = 1
t = 3        pulseON = 0
t = 10.5  pulseON = 1
t = 22     pulseON = 0
Hope I got you right.
                            Hi!
                                2011/05/13 14:41 GMT-4
I wonder if you manged to solve the problem
                                2011/06/20 13:41 GMT-4
                                                    Dear Andriy:
I tried to use the suggestion given by you on the blog and also tried to implement different suggestions on the Comsol Forum , but I havenot achieved desired result.
My Objective: Pulse width = 0.5ms, frequency = 10Hz, period = 1/frequency = 0.1s. Heating for 1sec and cooling for 5 sec.
Baed on your suggestion, pulseON=(mod(t,pulse_period)<=pulse_width), which is writen in my model as follows
Heat flux = avg_pd_new1 = avg_pd*(mod(t,0.1)<=5e-4)
My problem is : Even if I get the plot of pulse train of frequecy 10Hz and pulse width 0.5 ms, which I can plot on analytic function (an1), but my output remains ON only for the first pulse and rest is OFF.
Also, I did tried several other suggestion, which is plot in analytic function as an2,an3
Please suggest me some solution. I am attaching my model for reference.
Hitesh
                            Dear Andriy:
