Plotting a 3D Mirror Data Set to view Particle Trajectories- ERROR
Posted 2015/04/21 14:23 GMT-4 Charged Particle Tracing, Fluid & Heat, Particle Tracing for Fluid Flow, Results & Visualization Version 4.4 0 Replies
I have modelled half a pipe with particle trajectories in it, but I want to view the particle trajectories in the whole pipe. I tried doing so by creating a 3D Mirror Data Set.
I created a 3D Mirror Data Set and selected the particle trajectory (Particle 3) as the Data Set. The 3D Mirror of the pipe is plotted and is fine. The problem is when I change the data set for Particle Trajectories (fpt) into "Mirror 3D 2" instead of "Particle 3" and then in the sub-section, Particle Trajectories 1, I change the data set into "From Parent". I get an error:
Error: Operation cannot be performed on data set mir2(Mirror 3D).
Does anyone know the reason for that?
Thanks a lot
Hello Nadine Hassan
