Symmetric meshing
Dear all,
I'd like to learn if it is possible to have symmetry axis in mesh. I'm working on a 3D model, and the geometry is symmetric in both x and y axis. I'm studying on eigenfrequency analysis and I'd like the mesh to be symmetric in x-axis only.
To be more clear, I don't expect to see symmetric results for all mode shapes of course but when the mode shape is known to be symmetric by analytical means I want to see a more realistic illustration of it.
Utku
6 Replies Last Post 2017/11/25 22:19 JST
Posted: 1 decade ago 2015/04/30 8:47 JST
This is a really good question. With another package I've used this would happen by meshing the half-structure, then reflecting the meshed structure to generate a new meshed structure where the mesh was thus guaranteed symmetric to numerical precision. Is it possible to reflect after meshing?
Posted: 1 decade ago 2015/04/30 14:22 JST
have you really checked all mesh options/sub-nodes ?
You have thereunder copy mesh with or without mirror functions, no ?
COMSOL add new features for each release, so "my way" is to regularly click on all sub nodes and check that I remember all options down to the last leaf
Hi have you really checked all mesh options/sub-nodes ? You have thereunder copy mesh with or without mirror functions, no ? COMSOL add new features for each release, so "my way" is to regularly click on all sub nodes and check that I remember all options down to the last leaf -- Good luck Ivar
Posted: 1 decade ago 2015/04/30 22:10 JST
To be a little more specific:
1. First mesh one side.
2a) If the two domains which are symmetric have a common boundary, then it is sufficient to add a Copy Mesh or Copy Domain node in the mesh sequence. The mesh is automatically mirrored.
2b) If the who domains are disjoint, use a Copy Domain node, and add an Edge Map or Two-Point Map subnode to control the orientation of the copied mesh.
Henrik
Hi, To be a little more specific: 1. First mesh one side. 2a) If the two domains which are symmetric have a common boundary, then it is sufficient to add a Copy Mesh or Copy Domain node in the mesh sequence. The mesh is automatically mirrored. 2b) If the who domains are disjoint, use a Copy Domain node, and add an Edge Map or Two-Point Map subnode to control the orientation of the copied mesh. Regards, Henrik
Posted: 1 decade ago 2015/05/01 9:02 JST
Thank you all for your detailed replies. I haven't seen a 'mirror' node but I've seen copy domain node which I thought something different.
After I see your replies, I separated my 1 domain geometry into 2 symmetric domains and copy the mesh, it worked. Very quick and easy solution and the results are very satisfactory.
Thanks again,
Utku
Hi, Thank you all for your detailed replies. I haven't seen a 'mirror' node but I've seen copy domain node which I thought something different. After I see your replies, I separated my 1 domain geometry into 2 symmetric domains and copy the mesh, it worked. Very quick and easy solution and the results are very satisfactory. Thanks again, Utku
Posted: 8 years ago 2017/07/19 20:51 JST
This works. However, when adding an additional size-node with geometric entity level 'boundary' to the common boundary, the copy operation does not work any longer. Instead, it gives the error message: "different number of edge elements". How can I solve this problem?
Posted: 8 years ago 2017/11/25 22:19 JST
I have found another problem, i.e., if I put two domains together, which are exactly same, and share one same face, it seems I cannot use the 'copy domain' node? Do you have solutions
Thanks in advance.
HX
Hi, I have found another problem, i.e., if I put two domains together, which are exactly same, and share one same face, it seems I cannot use the 'copy domain' node? Do you have solutions Thanks in advance. HX
