Another Meshing Problem of 2 thin geometries
Hi!
I have the problem of meshing 2 thin geometries which form a union. If I mesh only the main part, it works. but meshing with free tetrahedal both i get the error:
Failed to respect boundary element edge on geometry face.
If I perform an triangular mesh and swep it, i get the following error:
Unsupported topology of boundary face.
The problem is, to connect the mesh from the first part with the second part. If I swep, the connected part is in a different plane, so the mesh would´nt connect!?
Does anyone knows how to create the mesh and further avoid singularities?
Thanks!
I attached the file
kind regards,
Steve
1 Reply Last Post 2010/07/19 15:08 JST
Posted: 1 decade ago 2010/07/19 15:08 JST
Hello!
Meanwhile I found a solution :-)
Meshing was possible by dividing the cross section in an upper and an lower part. So the narrow curve is interrupted an free meshing is possible!
kind regards,
Steve
Hello! Meanwhile I found a solution :-) Meshing was possible by dividing the cross section in an upper and an lower part. So the narrow curve is interrupted an free meshing is possible! kind regards, Steve
