Cantilever beam eigenfrequency
Hi all,
I am simulating eigenfrequency of a cantilever beam with 28mm length, 2mm width and 0.8 mm thick.
When I increase the width of the beam to 20mm and 200 mm the eigenfrequency increases in each case, which should not.
By using hand calculation and also 2D simulation, by increasing the width, the eigenfrequency should not increase!!
I have also tried with ANSYS and it is the same in 3D simulation by increasing the width of beam the eigenfreq. increases!!
Would you please tell me the reason.
Thank you,
2 Replies Last Post 2015/11/09 13:18 GMT-5
Posted: 1 decade ago 2015/05/15 2:08 GMT-4
Beam theory assumes plane stress conditions in the out-of-plane direction. This will be a good approximation only if the piece is thin.
Henrik
Hi, Beam theory assumes plane stress conditions in the out-of-plane direction. This will be a good approximation only if the piece is thin. Regards, Henrik
Posted: 1 decade ago 2015/11/09 13:18 GMT-5
i am new to comsol.I am trying to match the analytical results for eigenfrequency of a simple cantilever beam and its simulation results in comsol.I tried to implement many papers but i am failed to match what i am thinking there is some boundary condition is missing .just one boundary condition is used that is fixed constraint to fix a side .
Kindly help me out i will be very thankful to you .
Thanks in advance .
Khawar
Hi i am new to comsol.I am trying to match the analytical results for eigenfrequency of a simple cantilever beam and its simulation results in comsol.I tried to implement many papers but i am failed to match what i am thinking there is some boundary condition is missing .just one boundary condition is used that is fixed constraint to fix a side . Kindly help me out i will be very thankful to you . Thanks in advance . Khawar
