Sweep at different values of the same parameter....
Posted 2015/05/12 22:54 GMT-4 Version 4.4 2 Replies
Hi everyone. I want to measure change in magnetic flux density at different values of a parameter say xd. For this I used parametric sweep that works fine and gives accurate result but A parametric sweep allows you to tell COMSOL to run the same file with different input values of a parameter each time. I want comsol to consider all values of xd at a same time.
For instance xd = 0, 1, 2. If I make a 1D plot of change in magnetic flux density along x-axis it will give me peak value at 0, 1, and 2. With parametric sweep i get three plots one with peak = 0 the other with 1 and the third with 2. What i want is to have one plot indicating peaks at 0,1and 2.
Thanks....
Thanks....
2 Replies Last Post 2015/05/13 3:00 GMT-4
