Help needed: magnetostatic force calculation using Maxwell stress tensor
This problem has been bothering me for weeks. I read previous posts on this forum on topic of Maxwell stress tensor but still could not find what is wrong.
I'm trying to calculate the repelling force between two magnet rings with one levitated above the other. I defined a force variable for the top ring. COMSOL (AC/DC 3.3) gives "topring_nTz_emnc" as the surface force density at the boundaries of the top ring for calculating z-component of the force.
On the other hand, I manually defined elements of the Maxwell stress tensor as Global Expressions
T =(1/mu0)* [ Bx^2-0.5*|B|^2, BxBy, BxBz ;
ByBx, By^2-0.5*|B|^2, ByBz ;
BzBx , BzBy, Bz^2-0.5*|B|^2 ]
= [Txx, Txy, Txz;
Tyx, Tyy, Tyz;
Tzx, Tzy, Tzz];
Since I need to compute the z-component of the force, I used the Boundary Integration Coupling variable to calculate
Fz = int{nx*Tzx+ny*Tzy+nz*Tzz} dA
for each boundary of top ring. [nx ny nz] is the outward surface normal.
Here, nx*Tzx+ny*Tzy+nz*Tzz is also surface force density, which should agree with "topring_nTz_emnc" that is automatically generated by COMSOL.
However, I am getting different results. For some of the boundary surfaces (e.g. the inner and outer cylindrical faces of the top ring),
does not agree with
topring_nTz_emnc.
Any hints on what may have gone wrong?
Zhiyong
3 Replies Last Post 2013/06/20 21:07 JST
Posted: 2 decades ago 2010/07/20 3:40 JST
The model is attached here.
The geometry is very simple. Due to symmetry, only a quarter of the geometry is modeled.
The model is attached here. The geometry is very simple. Due to symmetry, only a quarter of the geometry is modeled.
Posted: 2 decades ago 2010/07/24 2:56 JST
Some update on this. I found that if the integration surface is completely removed from magnetic material boundaries (that is, completely in air/vacuum), two methods (see my original post or the summary below) gave very close results. However, they don't agree with each other when integrating right on the material surfaces.
So I guess the issue is related to how COMSOL implements the force density "domainname_nTz_emnc" on magnetic material surfaces?
summary of two methods:
Method 1:
Calculating total force components by integrating COMSOL built-in force density "domainname_nTz_emnc" over all external material surfaces
Method 2:
Calculating total force components by literally integrating Maxwell stress tensor "Tzx*nx+Tzy*ny+Tzz*nz" over some closed envelope containing the magnetic material
Some update on this. I found that if the integration surface is completely removed from magnetic material boundaries (that is, completely in air/vacuum), two methods (see my original post or the summary below) gave very close results. However, they don't agree with each other when integrating right on the material surfaces. So I guess the issue is related to how COMSOL implements the force density "domainname_nTz_emnc" on magnetic material surfaces? summary of two methods: Method 1: Calculating total force components by integrating COMSOL built-in force density "domainname_nTz_emnc" over all external material surfaces Method 2: Calculating total force components by literally integrating Maxwell stress tensor "Tzx*nx+Tzy*ny+Tzz*nz" over some closed envelope containing the magnetic material
Posted: 1 decade ago 2013/06/20 21:07 JST
Dear Mr. wang
please i have a work may be similar to your discussion, do mean the integration over the boundaries for example :
Fx : i should integrate both faces normal to X direction or just one face ?
me also i have a different results between the manual calculation for the Maxwell formula and in comsol formula,
so please if you solved this just tell me.
Best Regards
hassanain
Dear Mr. wang please i have a work may be similar to your discussion, do mean the integration over the boundaries for example : Fx : i should integrate both faces normal to X direction or just one face ? me also i have a different results between the manual calculation for the Maxwell formula and in comsol formula, so please if you solved this just tell me. Best Regards hassanain
