Identity Pairs in Comsol 4.0
I have just started using the new version of Comsol and I have a small question.In the 3.5a version of Comsol when we use the "Create Pairs" option, there are 2 mapping operators to refer them i.e src2dst_ip** and dst2src_ip**.
When I want to create pairs in the newer version of Comsol,I see only the pair name and no mapping operators . Can some help me with this? What are the mapping operators called in the new version?
Any sort of help would be useful.
Thanks.
Best Regards,
Nihit.
1 Reply Last Post 2010/07/21 4:28 GMT-4
Posted: 2 decades ago 2010/07/21 4:28 GMT-4
In V4 when you make pairs, you must :
1) define them in "Model - Definitions (right click) - Pair
2) and in Model - Physics (solid or whatever) (right-click) - Pairs (selectthe appropriate)
Then if you have turned the equations on in the "options - preferences" you will find all you need, I believe
Hi In V4 when you make pairs, you must : 1) define them in "Model - Definitions (right click) - Pair 2) and in Model - Physics (solid or whatever) (right-click) - Pairs (selectthe appropriate) Then if you have turned the equations on in the "options - preferences" you will find all you need, I believe -- Good luck Ivar
