error installing comsol 4.0 silent mode
Posted 2010/07/21 19:21 JST 1 Reply
Hi.
We are about to distribute comsol 4.0 to multiple clients, and having som issues with the silent mode install.
I have tested the normal install and this is working correctly. When i try to install with -s i get error message that points to log file.
log file contain this:
!ENTRY org.eclipse.osgi 4 0 2010-07-21 11:44:39.838
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
we want this installed on win7 64bit. what do i need to do to get the install to function proper.
in install.pdf it points to setup.ini file, but the default ini file contains this info
# Settings for COMSOL installer on win32
install
-startup
plugins\org.eclipse.equinox.launcher_1.0.201.R35x_v20090715.jar
--launcher.library
plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.0.200.v20090519
--launcher.XXMaxPermSize
256M
-vm
java/win32/jre/bin/client/jvm.dll
-vmargs
-Dosgi.configuration.cascaded=true
-Dosgi.clean=true
-Dosgi.checkConfiguration=true
-Dosgi.sharedConfiguration.area=file:configuration/comsol
-Dosgi.sharedConfiguration.area.readOnly=true
-Dosgi.configuration.area=@user.home/.comsol/v40/configuration/comsol
-Dosgi.instance.area=@user.home/.comsol/v40/workspace/comsol
-Dcs.logoutput=file
-Dcs.logfileprefix=comsol
-Dosgi.noShutdown=true
-Dcs.install=true
-Xss2m
-Xms40m
-Xmx512m
however there are a setupconfig.ini file that contiains the syntax for the setup.ini and when i change these files, its like the 3.5 version was. then i get to error mentioned above.
!STACK 1
install
-startup
--launcher.library
256M
-vm
-vmargs
-Dosgi.clean=true
-Dcs.logoutput=file
-Dcs.install=true
-Xss2m
-Xms40m
-Xmx512m
1 Reply Last Post 2010/08/06 22:51 JST
