Solution crushed by using second application mode
Posted 2010/07/21 7:18 GMT-4 1 Reply
Hi everybody,
I use COMSOL using two application modes.
1) First, I use the PDE mode / Weak Form Boundary using the eigensolver to solve an eigenvalues equation.
The solution is found and COMSOL gave me a set of eigenvalues (lambda_i) and eigenmodes (u_i) for i=1 to 10...
---> ok
2) Then, I use the second application mode PDE general Form using the time dependant solver to solve an other equation (time dependant) using the previous solutions (ie lambda_i and u_i). I would like solve this second problem for each solutions (lambda_i , u_i) found previously...
The problem is that COMSOL solve this second problem only for the current solution (I mean for only one solution lambda_2 , u_2), not for all previous solutions.
More, the different lambda are not available after this second step...
I tried to use solve / solver manager and Initial value to keep my first solutions but this does not work !
Please have you an idea to my problem ?
Thank you !
Mathias Clervoy
---> ok
Thank you !
Mathias Clervoy
1 Reply Last Post 2010/07/21 12:01 GMT-4
