Modelling a swirling gas
In my CFD model I receive gas from a process through a pipe. The gas in the pipe is swirling, i.e. besides the axial velocity vector there is a tangential velocity vector. Does anybody know how I can set up the boundary inlet conditions so that I can make the gas swirl?
Many thanks,
Calle
3 Replies Last Post 2015/02/15 14:53 JST
Posted: 2 decades ago 2010/07/24 16:38 JST
cant you define a cylindrical coordinate V4 (r,phy,a) and use that to define your initial conditions ?
Hi cant you define a cylindrical coordinate V4 (r,phy,a) and use that to define your initial conditions ? -- Good luck Ivar
Posted: 2 decades ago 2010/07/24 20:45 JST
Thanks for your reply. I would prefer to finish this model in V35 as it is already well under way. Also, I am not sure how to cope with that the downstream geometry is not axis symmetric. The model is truly 3D.
Some years ago I worked with V32. It had a function "s" (s1, s2 and s3 in 3D) which was very useful for creating assymetric and time dependant functions on the inlet flow. However the s function does not work on V35. Is there a substitute?
Calle
Hi, Thanks for your reply. I would prefer to finish this model in V35 as it is already well under way. Also, I am not sure how to cope with that the downstream geometry is not axis symmetric. The model is truly 3D. Some years ago I worked with V32. It had a function "s" (s1, s2 and s3 in 3D) which was very useful for creating assymetric and time dependant functions on the inlet flow. However the s function does not work on V35. Is there a substitute? Thanks, Calle
Posted: 1 decade ago 2015/02/15 14:53 JST
WHY cant you try swirl dominant flow and add a swirl factor of 0.5. model k-epsilon
