Magnetization independent variables
I am trying to model a material with the AC/DC module using 3.5a and I have equations which describe the magnetization of the material in the horizontal (x) and vertical (y) directions. BOTH equations use the horizontal magnetic field to determine the magnetization (Bx_emqa).
I am using the constitutive relation B=mu0(H+M) and defining M as the equations I described above. This creates problems when I try and solve the model as I think COMSOL will not allow me to define magnetization in the vertical (y) direction with a horizontal field (x direction). Can anyone verify this for me? Does anyone have any ideas on how I can represent the horizontal field without using Bx_emqa/mu0? I have already tried defining Bx as sqrt(normB^2 +By^2) , but that doesn't work either. Functions maybe? or some other way?
Thanks for your help.
2 Replies Last Post 2010/07/26 22:51 JST
Posted: 1 decade ago 2010/07/24 21:17 JST
did you define the derivative of the material function ? I believe this is mandatory, check the doc
Hi did you define the derivative of the material function ? I believe this is mandatory, check the doc -- Good luck Ivar
Posted: 1 decade ago 2010/07/26 22:51 JST
Thanks for your help. After receiving your comment I manually defined the material derivative for each variable, but the system still does not converge. If I remove Bx_emqa from the My definition box, the system does converge. Do you have any other suggestions? Thanks again.
