Hello Salwa Mostafa
2010/09/14 2:56 JST
I have the same problem with the scale not remaining constant in v4.0 as it did in 3.5.
2010/09/14 3:28 JST
Chris,
I found out that you have to generate the 3-D plot by right click on result> 3D plot every time you simulate. If you have saved a .mph file with using "save as" with a new name that already had a 3D plot in the results section, and changed a few things in the new file and simulated again, then the 3-D plot wont know the time information (in case time dependant solver) and will not show it in 3D-plot. So in such case, you have to create a new 3-D plot.
As for scaling. You can fix the data and color range in the plot settings. The variable range I was seeing was actually the maximum and minimum value of the data in that frame. Suppose you fixed the color range from 270 to 350. The color distribution throughout the frames will stay the same, but the maximum and minimum value will show on top and bottom of the color axis for the given frame. Example: In one frame my max/min value was 273/274. So although the range showed 273 at the bottom near blue color and 274 at the top close to red color, the temperature distribtion in the structure was all blue (around 273-4).
Another thing you may notice if you fix the maximum value of the manual color range below maximum data value you get from the simulation, COMSOL will show that area as white/ blank. So that was something to be careful about.
Hope this helps.
Chris,
Hope this helps.
