setting "air" pressure
Posted 2015/05/26 17:11 GMT-4 MEMS & Nanotechnology, MEMS & Piezoelectric Devices, Structural Mechanics Version 5.1 1 Reply
This is a really basic question and I apologize for asking it, but have mercy on me.
I want to emulate vacuum for electromechanical actuation, so I use an "air" material. The "air" material properties include air density, which is a function of pressure ( "pA") and temperature ("T"). If I wish to set these variables, I set them in Global Definitions -> Parameters, for example, here I'm setting the air pressure to 1 µPa:
i.imgur.com/nBKBRU7.png
Is this correct?
Further, in the solid mechanics module, I need to set the Young's modulus of the gas to "pA". This is consistent with the definition of pressure of an ideal gas: reducing the length of a gas cylinder of length L to length L - dL increases the pressure from pA to pA L / (L - dL) ≈ pA ( 1 + dL / L ). The "strain" in this case is -dL/L, and the "stress" is dL/L pA, so the effective Young's modulus is the ratio = pA. It's curious this isn't built into the model and needs to be specified, but in any case my pressures are so low it's effectively zero (exactly zero generates a singular matrix).
Further, with solid mechanics and air there is no need to use the moving mesh module, if I read the documentation correctly.
Whoops -- I've deviated substantially from my original question, which was whether "pA" is specified as a global parameter definition.
Is this correct?
1 Reply Last Post 2015/05/28 14:58 GMT-4
