2 decades ago
2010/08/03 4:44 JST
the heaviside functions are symmetric, so you need to add (or substract) an offset corresponding to the rise time to start at "0". Use the plotting capability to check your functions
2 decades ago
2010/08/03 4:58 JST
Hi Ivar
Thank you very much for your comment. I have 5 stepping times. When i use Heaviside fuctions for each of these stepping times. This is how i am writing the formula. E1-flc1hs((t-St)/time,0.0001)*(E1-E2) here E1 and E2 are potentialsand t is time St is stepping time. time is to normalized the left side. When i plot the fuction there is a value of 0.5(E1+E2) when the (t-St) =0. I need to get over this value. all the other time it is either E1 or E2.
Thank you
Chandima
Hi Ivar
Thank you
Chandima
2 decades ago
2010/08/03 16:30 JST
I do not really catch your question, as for me that is very normal flc1hs(x,step) is a smooth transition of width 2*step stating at x=-step and ending at x=+step with a transition of 0 to 1.
so clearly while your value is E1 up to your (t-St)/time <= -0.0001 and is equal to E1-(E1-E2)=E2 while (t-St/time >=+0.0001, and is equal to the mean E1-(E1-E2)/2=(E1+E2)/2 for (t-St)/time=0 the mid point
You might be using a very short transition 0.0001 compared to your solver steps. If you leave COMSOL solving, it will adapt and most probably calculate a few points during this transition, but then would not save them if you have not selected to save intermediate step values
so clearly while your value is E1 up to your (t-St)/time =+0.0001, and is equal to the mean E1-(E1-E2)/2=(E1+E2)/2 for (t-St)/time=0 the mid point
2 decades ago
2010/08/04 7:20 JST
Hi Ivar,
Thank you very much for your comment. Once i used realy small number for the Heaviside fuction (step) only few points are there. But i try to use operator if(t>1,expr1,expr2) (t is time) it didnt work. Thank you very much
Chandima
Hi Ivar,
Chandima
2 decades ago
2010/08/04 14:46 JST
Do not mix, the heaviside function is defined "independently" of the points of the solver. What often happens is that the solver has problems to "see" the short step functions, then you must help it on its way, by defining manual time steps that are "thight" around the transitions,
I mostly use the solver in automatic mode, and just define some 5-10 points on all my transitions, and few in-between
2 decades ago
2010/08/04 22:49 JST
Hi Ivar,
I am using Time dependent solver with time range(0,0.01,6) and make relative tolerance 0.001 and absolute tolerance 0.00010 with linear system solver Direact(UMFPACK). This one take more than hours to solve the problem even though degrees of freedom 379122. Need to think about faster way to solve the problem. Thank you
Chandima
Hi Ivar,
Chandima
2015/05/20 21:15 JST
sir i am working on comsol 4.4 . i want to set up pressure as a heaviside function of time. how to set up heaviside function in comsol.
