LiveLink compatibles
What version of SolidWorks is being supported by LiveLink in 4.0a version of COMSOL?
"The LiveLink for COMSOL add-in is not correctly registered with SolidWorks" i have this message right after i press Synchronize button, does this mean i have wrong SolidWorks version or else?
6 Replies Last Post 2010/11/03 3:54 GMT-4
Posted: 2 decades ago 2010/08/04 1:31 GMT-4
I have used SW 2009SP4.1 and 2010sp3.1, currently testing 2010_sp4.1 (for today ;)
Hi I have used SW 2009SP4.1 and 2010sp3.1, currently testing 2010_sp4.1 (for today ;) -- Good luck Ivar
Posted: 2 decades ago 2010/08/04 2:16 GMT-4
Thanks for reply. And what does this "The LiveLink for COMSOL add-in is not correctly registered with SolidWorks" mean then? I had installed SolidWorks before COMSOL btw, and followed instructions from help.
Posted: 2 decades ago 2010/08/04 3:19 GMT-4
not sure i o not have that message, have you checked the SW tools add-ins and that LiveLink is checked (active and at alunch ? (at least one is required)
which version of SW do you ahve ?
Hi not sure i o not have that message, have you checked the SW tools add-ins and that LiveLink is checked (active and at alunch ? (at least one is required) which version of SW do you ahve ? -- Good luck Ivar
Posted: 2 decades ago 2010/11/02 13:32 GMT-4
Did you get an answer to this? I found KB1033 (www.comsol.com/support/knowledgebase/1033/) and plan to try it as soon as my IT department gives me admin access. If that works I can report here... if you found another solution I'd appreciate a hint.
Dave
[QUOTE] What version of SolidWorks is being supported by LiveLink in 4.0a version of COMSOL? "The LiveLink for COMSOL add-in is not correctly registered with SolidWorks" i have this message right after i press Synchronize button, does this mean i have wrong SolidWorks version or else? [/QUOTE] Did you get an answer to this? I found KB1033 (http://www.comsol.com/support/knowledgebase/1033/) and plan to try it as soon as my IT department gives me admin access. If that works I can report here... if you found another solution I'd appreciate a hint. Dave
Posted: 2 decades ago 2010/11/02 16:36 GMT-4
Dave
That didn't seem to work. I got the following error when I tried the regsvr32 command:
"DllRegisterServer in C:\(path to cslivelinksw.dll) failed. Return code was: 0x80070005"
The later steps in the KB article talk about looking for the Add-in within SolidWorks, but the add-in does not show up on the list.
Dave
[QUOTE] [QUOTE] What version of SolidWorks is being supported by LiveLink in 4.0a version of COMSOL? "The LiveLink for COMSOL add-in is not correctly registered with SolidWorks" i have this message right after i press Synchronize button, does this mean i have wrong SolidWorks version or else? [/QUOTE] Did you get an answer to this? I found KB1033 (http://www.comsol.com/support/knowledgebase/1033/) and plan to try it as soon as my IT department gives me admin access. If that works I can report here... if you found another solution I'd appreciate a hint. Dave [/QUOTE] That didn't seem to work. I got the following error when I tried the regsvr32 command: "DllRegisterServer in C:\(path to cslivelinksw.dll) failed. Return code was: 0x80070005" The later steps in the KB article talk about looking for the Add-in within SolidWorks, but the add-in does not show up on the list. Dave
Posted: 1 decade ago 2010/11/03 3:54 GMT-4
Sorry, dude. This solution worked fine to me.
Ivan
Sorry, dude. This solution worked fine to me. Ivan
