"Empty Expression"
I am trying to run a Free Tetrahedral mesh on a project I've designed. However, when I attempt to add a distribution to the simulation, it refuses to and gives a pop-up error of "Empty Expression."
Any idea why it is doing that? Thanks.
1 Reply Last Post 2015/06/08 1:44 JST
Posted: 1 decade ago 2015/06/08 1:44 JST
Normally that means an required entry is all empty (normally you leave a "0" or a "1" or something relevant in ALL model tree field entries).
Or it means you have forgotten to define the Entities on to which your Distribution applies, these are different (or might be) from the ones of the main mesh node
Hi Normally that means an required entry is all empty (normally you leave a "0" or a "1" or something relevant in ALL model tree field entries). Or it means you have forgotten to define the Entities on to which your Distribution applies, these are different (or might be) from the ones of the main mesh node -- Good luck Ivar
