Moving Mesh issues in v4
Posted 2010/08/10 10:27 GMT-4 1 Reply
I am attempting to port a model from v3.5 to v4 which uses the moving mesh(ale) interface. The model was working properly in v3.5 but I have had some issues getting the expected behavior in v4. I am attaching 2 simplified versions of what I am trying to do which demonstrate the issues I am running into. To my knowledge the 2 attached versions are identical except for the fact that the physics interfaces were added to the model in different orders.
a) ES_ALE_v1.mph – the electrostatic interface was added first then the moving mesh interface was added
b) ALE_ES_v1.mph – the moving mesh interface was added first then the electrostatic interface was added
I think there maybe be a bug which is causing the difference in behavior, do you agree?
Regardless, neither version is behaving as I'd like. Version a) is graphically displaying what I think the simulation is actually calculating though.
In Version b) – 2D Plot Group 1 – select time 0.6. As you can see block #4 has moved up as expected and is also a solid deep red. This is expected also since a fixed voltage of 10 is being applied to it's boundaries. However clicking on the solid red block within the block #3 region shows that the voltage is not 10v there. Instead it is something less.
In Version a) one can observe the movement of block #4 by going to 2D Plot Group 1 – select time 0.6 and Frame: Spatial. In this case you see that the mesh has moved as expected but the voltage does not follow the boundaries of the moving mesh.
I need to move block #4 and have it remain at 10v all the time. The rest of the model should respond accordingly based on the movement of block #4. Any suggestions you could provide are welcome.
1 Reply Last Post 2010/08/20 13:53 GMT-4
