Mesh problem
Posted 2015/07/02 19:52 GMT-4 Version 5.0 5 Replies
                                                    Hi, my project has a gold wire with diameter of 25um over a piece of square substrate with 5 x 5 mm. I am having a problem with the simulation of magnetic field, because the mesh does not to converge correctly.
If I use a normal mesh I have the message "Inverted mesh element near coordinates (0.0025, 0.00440518, 0.0008125)", if I have a Extremely Fine mesh, I take a long time to process, so until this moment my best solution is a user controlled mesh custom to a big maximum element size (1) and a very little minimum element size (0.005) with a element growth rate of 2 and a resolution of 1.
Is that correct ? Is there another solution more efficient?
Thank's.
Thank's.
5 Replies Last Post 2015/07/03 12:44 GMT-4
