Obtaining accurate geometry from deformed mesh ('mesh2geom', ALE mode)
Posted 2009/09/22 19:19 GMT-4 0 Replies
I am using ALE module and once the quality of mesh degrade below specified limit, the solver stops and i use mesh2geom to recreate the geometry from deformed mesh and restart solver.
It works well for some time. After certain time-step, the difference between original geomtery and the one i created from deformed mesh grows and all kinds of problem (failed to insert point, invalid cavity, inconsistent initial guess) etc. kick in. All these problems occur at the curved boundary, while i tried playing with fine mesh along this boundary, it doesn;t seem to work as of now.
Any suggestions to work around this problem? how to accurately extract geometry using mesh2geom ?
I thought of re-creating original shape/geometry after some threshold time but that changes the boundary numbers and then i need to change (automate) a whole lot of things in the model, couping variables, boundary conditions etc. As previous posts suggest, i can use geomanalyze to track the change in edge numbering but there may be a smart way?
Also, is there any way, we can fix the edge numbers in any geometry?
Any help is appreciated.
Mranal
Hello Mranal Jain
