Matlab Link plot result with maximun parameter value
I am currently working with the LiveLink with Matlab module. I have a model with several studies and therefore several data sets. Each study use a parametric resolution, and sometimes with different numbers of parameter.
I am trying to write a script that save from one plot group automatically the figures for all datasets.
So i use a for i loop.
I change dataset with : "Model.result('pg1').set('data', 'dset i')", and I use "Model.result('pg1').setIndex('looplevel' , '55' , 0) " to plot the results with de 55th value of the parameter.
I want to automatically use the last value of the parameter. I try to use "Model.result('pg1').setIndex('looplevel' , 'maximum' , 0) " but it didn't work.
Is there a way to do that?
At least is there a way to get the numbers of paramters in this dataset?
Thank you
1 Reply Last Post 2015/07/28 23:00 JST
Posted: 1 decade ago 2015/07/28 23:00 JST
For those who are looking for the same answer, I found a way.
You can use:
S=mpheval(Model , '1', 'dataset', 'dsetX');
s=size(S.d1);
and s(1) is the last parameter number for the Xth dataset.
Hello, For those who are looking for the same answer, I found a way. You can use: S=mpheval(Model , '1', 'dataset', 'dsetX'); s=size(S.d1); and s(1) is the last parameter number for the Xth dataset.
