2015/08/04 18:27 JST
According to what I understood from your problem set-up, I attach here my solution. Note that substrate is initially everywhere at concentration S but is consumed in the reaction. The distances are so small that the entire space is filled with product rather quickly.
BR
Lasse
BR
Lasse
2015/08/04 20:13 JST
Hi Lasse,
I cant open the file, its in later version.
Hi Lasse,
2015/08/04 22:04 JST
Which version do you have?
2015/08/04 23:04 JST
I have COMSOL 4.4
I have COMSOL 4.4
2015/08/05 1:03 JST
I made a report of the model. It is not very clear, if I may say so, but I have two variables c1 (product) and c2 (substrate) which diffuse in the entire domain [0,L]. The reaction takes place in the domain [0,d]. At x = 0 and x = L I have No Flux condition. At point x = d no BC is needed at all, neither another separate Convection and diffusion node. I deactivated convection, so it does not appear at all in the node.
Reaction Rsp = Vmax*c2/(Km + c2); it must be defined as a variable under Component Definitions, not global. I deleted all variables under Global Definitions.
I used time stepping 0,10^{range(-6,0.2,0)} because the reaction rate is at highest in the beginning.
Wish this helps
Lasse
Wish this helps
Lasse
10 years ago
2015/08/05 19:58 JST
I need at x=d there should be a flux(P) and concentration(P) continuity. I don't need a boundary condition for that?
10 years ago
2015/08/05 20:01 JST
No. Comsol assumes continuity of fluxes and concentrations unless you deliberately wish to change it. That could be due to, say, partitioning between the aqueous and organic phases.
