3.5a> Struct. Mech.> Circular, Frictional Sliding Constraint
Posted 2010/08/20 0:30 GMT-4 Structural Mechanics Version 4.2 2 Replies
Suppose I have a large metal plate with a large circular hole drilled into it.
Now I spread a thin, flexible sheet above this metal plate, and push inward through the hole.
The sheet will displace through the circular hole and down below, and its motion will be confined to the circular constraint of the structure of the hole. There also will be frictional effects.
How can I model this with COMSOL? Can I do it with 3.5a, and if so, which physics application(s) should I use?
Basically, most important is learning how to specify this circular constraint, and of less importance is the frictional force specifications.
Thank you.
Kevin
Thank you.
Kevin
2 Replies Last Post 2011/08/22 13:00 GMT-4
