2 decades ago
2010/08/23 18:12 JST
one thing in COMSOL; always check carefully the units, loads are in "pressure" (Pa=N/m^2) so you need to be sure you apply them to the corresponding surfaces, edge length or denisty (for body loads) to have correct units.
In 2D you are calculating in fact in 3D with a default depth of typically 1[m] (but you might have defined soemthing else, then you need to mulétiply or divide (depends on your folmular) by this thickness to get coherent units.
In 2D-axi its the "loop length" =2*pi*r one must not forget (in certain cases as for BC's it can be taken in (just as for thicknesses in 2D) by a "click" box
Often you need to integraste the results ofer an area (respective edge*thickness in 2D) to get the total results as forces (except for global reaction forces that are summed up).
The best is to test simple cases, and read the doc (again and again ;)
