identity pairs setting
Posted 2009/06/29 7:35 GMT-4 0 Replies
I am looking for simulate a mechanical joint among sheet metal parts. During the first step parts have to be clamped (so contact pairs are defined). Then, once the contact is assured a mechanical joint (such bolt, glue, spot weld) is introduced. In this phase I assume that the mechanical joint is rigid and the I'd like to model it with an identity pair. The problem is: is it possible to change the tolerance value (if it exists) which comsol uses to detect if two boundaries are identity or not?
Thanks for your attention
Regards
Pasquale
Hello Pasquale Franciosa
