Problem with COMSOL5 and MATLAB
I am trying running COMSOL with MATLAB, and when I run my code I get the following error. Does anyone have any idea what is wrong.
I am using COMSOL5.0 on ubuntu 14.04, and I have tried both MATLAB 13b and 15a.
The code up to the stop point is:
import com.comsol.model.*
import com.comsol.model.util.*
model = ModelUtil.create('Model');
model.modelPath('/home/rahmani/Ratchet/Comsol');
model.comments(['Untitled\n\n']);
model.modelNode.create('comp1');
model.geom.create('geom1', 2);
and the error is:
Java exception occurred:
Exception:
java.lang.UnsatisfiedLinkError: com.comsol.nativejni.geom.Geom2.createGeom2(Lcom/comsol/nativejni/CPointer;I)V
(rethrown as com.comsol.util.exceptions.FlException)
Stack trace:
at com.comsol.nativejni.geom.Geom2.createGeom2(Native Method)
at com.comsol.nativejni.geom.Geom2.<init>(Unknown Source)
at com.comsol.nativemph.geom.Geom2.<init>(Unknown Source)
at com.comsol.model.method.GeomSequenceMethod.setEmptyGeom(Unknown Source)
at com.comsol.model.internal.impl.GeomSequenceImpl.doSetEmptyGeom(Unknown Source)
at com.comsol.model.internal.impl.GeomSequenceImpl.setEmptyGeom(Unknown Source)
at com.comsol.model.method.GeomSequenceMethod.doInitialize(Unknown Source)
at com.comsol.model.internal.impl.GeomSequenceImpl.doInitialize(Unknown Source)
at com.comsol.model.internal.impl.ModelEntityImpl.initialize(Unknown Source)
at com.comsol.model.internal.impl.GeomListImpl.doCreate(Unknown Source)
at com.comsol.model.internal.impl.GeomListImpl.a(Unknown Source)
at com.comsol.model.internal.impl.GeomListImpl$1.a(Unknown Source)
at com.comsol.model.internal.impl.GeomListImpl$1.execute(Unknown Source)
at com.comsol.model.clientserver.ClientManager$1.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
2 Replies Last Post 2015/08/24 11:19 GMT-4
Jim Freels mechanical side of nuclear engineering, multiphysics analysis, COMSOL specialist
Posted: 1 decade ago 2015/08/21 17:40 GMT-4
I assume when you say that you have MATLAB 13b and 15a, you have tried both R2013b and R2015a ?
Did you follow the installation instructions ?
Do you have the MATLAB livelink product ?
Have you adjusted the COMSOL preferences to point to the MATLAB installation directory ?
What shell are you running under Ubuntu ? bash, csh, ksh, etc...
How did you start COMSOL / MATLAB together ? MATLAB from COMSOL, or COMSOL from MATLAB ?
I assume when you say that you have MATLAB 13b and 15a, you have tried both R2013b and R2015a ? Did you follow the installation instructions ? Do you have the MATLAB livelink product ? Have you adjusted the COMSOL preferences to point to the MATLAB installation directory ? What shell are you running under Ubuntu ? bash, csh, ksh, etc... How did you start COMSOL / MATLAB together ? MATLAB from COMSOL, or COMSOL from MATLAB ?
Posted: 1 decade ago 2015/08/24 11:19 GMT-4
The problem was in starting the COMSOL and MATLAB.
I used "comsol matlab" to start it but the correct way is "comsol server matlab".
[QUOTE] I assume when you say that you have MATLAB 13b and 15a, you have tried both R2013b and R2015a ? Did you follow the installation instructions ? Do you have the MATLAB livelink product ? Have you adjusted the COMSOL preferences to point to the MATLAB installation directory ? What shell are you running under Ubuntu ? bash, csh, ksh, etc... How did you start COMSOL / MATLAB together ? MATLAB from COMSOL, or COMSOL from MATLAB ? [/QUOTE] The problem was in starting the COMSOL and MATLAB. I used "comsol matlab" to start it but the correct way is "comsol server matlab". Thanks
