Linear Solver Error
While running a transient model, I am getting following error:
Error:
Time 0.009999999999999999:
Repeated error test failures. May have reached a singularity.
From the plots, it looks like transient forces have settled down (i.e reached steady state) then the problem is occuring and solver is not processing any more . It stops right there.
Could anyone help me in this?
S. Paul
1 Reply Last Post 2010/08/28 18:27 JST
Posted: 2 decades ago 2010/08/28 18:27 JST
transient is always tricky ;)
I can only suggeest what I do when I get such errors:
- to check my initial consitions, are these "far away" or have I put starting values close to the expected ones ?
- and are my time dependent functions (if I have any) smooth and compliant with the stime stepping and tolerances I have in the solver
Hi transient is always tricky ;) I can only suggeest what I do when I get such errors: - to check my initial consitions, are these "far away" or have I put starting values close to the expected ones ? - and are my time dependent functions (if I have any) smooth and compliant with the stime stepping and tolerances I have in the solver -- Good luck Ivar
