Running License Server without Logging in, Windows XP 64 bit
I'm running the license server on a separate computer from my COMSOL machine. Everything is working okay, except that I have to log on to the license server machine and start the license manager before logging on to the COMSOL machine to run COMSOL. Also, I have to stay logged on to the license server machine to keep the license server running. If I log off, the license server stops.
Is there a way to set up the license server machine so it starts up the license server on boot and runs the license server independent of users logging on and off?
John
2 Replies Last Post 2010/08/30 16:28 GMT-4
Posted: 2 decades ago 2010/08/28 5:03 GMT-4
normally a licence server should be set up as a service running in "automatic" mode so no login (apart from an admin account the first time to install) should be required
check the way you have installed the licence server, perhaps you need to do it again, or you have missed a check bos (start on boo) or sometings similar, but all this is very OS dependent
There are also a few knowledge base pages about licence server set-up to help, browse the comsol website
Hi normally a licence server should be set up as a service running in "automatic" mode so no login (apart from an admin account the first time to install) should be required . check the way you have installed the licence server, perhaps you need to do it again, or you have missed a check bos (start on boo) or sometings similar, but all this is very OS dependent There are also a few knowledge base pages about licence server set-up to help, browse the comsol website -- Good luck Ivar
Posted: 2 decades ago 2010/08/30 16:28 GMT-4
Thanks, clicking the check boxes to run as a service and start on boot took care of the issue. I had looked through the website and the installation documentation but didn't locate instructions for what I needed to do.
A previous graduate student had originally set the system up, so I wasn't aware of all of the options. Running lmtools to start the license server before running COMSOL was fine until we added a second computer.
John
Thanks, clicking the check boxes to run as a service and start on boot took care of the issue. I had looked through the website and the installation documentation but didn't locate instructions for what I needed to do. A previous graduate student had originally set the system up, so I wasn't aware of all of the options. Running lmtools to start the license server before running COMSOL was fine until we added a second computer. Thanks, John
