Nirmal Paudel
COMSOL Employee
2015/09/03 4:06 JST
Please take a look at the following example which demonstrate the coupling between the "Single Turn Coil" in 3D with the "Electrical Circuit", but for stationary study. The coupling technique between the Coil and the Electrical Circuits interface is almost same for "Single Turn Coil" or "Multi-Turn Coil".
www.comsol.com/model/modeling-of-a-3d-inductor-10299
Hope this example will be useful.
Best Regards,
Nirmal Paudel
http://www.comsol.com/model/modeling-of-a-3d-inductor-10299
Best Regards,
Nirmal Paudel
2015/09/03 9:56 JST
Thank you sir. Let me see this. Then I'll come back if I have some other query.
Tapabrata Sen
Tapabrata Sen
10 years ago
2015/09/04 22:20 JST
I've gone through the one you said sir and also other tutorials related to what I said earlier. But I should clarify a little more about what I want.
As I said I am following 'Multi-Turn Coil Above an Asymmetric Conductor Plate' tutorial, so this shows the effect of eddy current and also corresponding effects of magnetic field. Now in my circuit where I've used a sinusoidal current source of a definite frequency, the eddy current and magnetic field should also be time varying of same frequency. So I want to plot the magnetic field/eddy current sinusoidal response along with input sinusoidal to see time domain shift(in fact phase) in the response.
So sir firstly I'm confused with which study step should I use. In time dependent study there is only option to plot time domain signal of the coil or circuit components' voltage, current only. And in frequency response where all magnetic field parameters etc are there, I don't see a way to plot time signal of the magnetic field.
(I'm using Comsol 4.3a)
Hope I'm able to convey my point. I'm looking forward that someone will help me out.
Thank and regards,
Tapabrata Sen
Thank and regards,
Tapabrata Sen
