Restore model
My computer shut down itself and I had not saved changes to my model. Could anybody guide me how can I restore my unsaved model?
Appreciate the help
Thank you
Best regards
1 Reply Last Post 2015/09/11 0:59 JST
Posted: 10 years ago 2015/09/11 0:59 JST
Problem Description
This knowledgebase describes how to benefit from the recovery feature in COMSOL 4.1 and later. This is particularly useful if you have a long computation that for some reason was interrupted at some point, maybe due to system instability, or a network problem or power outage.
Solution
You can retrieve data that might have been saved by the automatic recovery feature.
Select File > Open Recovery File and open the file with correct date.
Save the file as a new file.
In the new file, you should be able to right-click Study and select Continue instead of Compute in
order to continue the solution process.
www.comsol.com/support/knowledgebase/1112/
Good luck!
Problem Description This knowledgebase describes how to benefit from the recovery feature in COMSOL 4.1 and later. This is particularly useful if you have a long computation that for some reason was interrupted at some point, maybe due to system instability, or a network problem or power outage. Solution You can retrieve data that might have been saved by the automatic recovery feature. Select File > Open Recovery File and open the file with correct date. Save the file as a new file. In the new file, you should be able to right-click Study and select Continue instead of Compute in order to continue the solution process. http://www.comsol.com/support/knowledgebase/1112/ Good luck!
