Gunnar Andersson
        COMSOL Employee
                                2015/09/14 2:07 GMT-4
                                                    This sounds like a job for the Parametric Curve 2D data set.
                                2015/09/14 2:26 GMT-4
                                                    Thanks for the reply Gunnar. I used the parametric curve 2D but what expressions should i write in the x and y to have a circle. I used the expression r*cos(range(0,0.01,2*pi)) and r*sin(range(0,0.01,2*pi)) for the x and y but the range function does not work it is giving the message of unknown function or operator range.....
Thankssss
Thankssss
                                Gunnar Andersson
        COMSOL Employee
                                2015/09/14 2:31 GMT-4
The x and y fields expect expressions defined in terms of a parameter. Try the following:
Minimum: 0
Maximum: 2*pi
x: r*cos(s)
y: r*sin(s)
                            [QUOTE]
[/QUOTE]
Minimum: 0
Maximum: 2*pi
x: r*cos(s)
y: r*sin(s)
                                2015/09/14 21:58 GMT-4
                                                    Thanks i got your point. I tried but it is giving the message
Cannot evaluate the expression
Failed to evaluate variable.
 - Variable: s
 - Geometry: 1
 - Boundary: 1 2 4 5 7 8 9 15 53 54 67 77 79 98 99
 - Expression: cos(s)
 - Plot: previewplot1 (Line)
 - Variable: s
 - Geometry: 1
                                2015/09/14 22:01 GMT-4
                                                    thanks it worked.... thanks alot for the information....
