Integration coupling
Posted 2015/09/14 16:15 GMT-4 Version 5.1 0 Replies
I'm trying to get the temperature at a point on the surface of a geometry. I was informed that I need to use integration component coupling to do that. When I was trying to use the integration component coupling, I found that It can only apply to an existing point of the geometry(i.e.: the corners of a rectangle).
Is there any way that I can get the temperature at an arbitrary position on a surface. Also, after I define the coupling, how do I use it to get the temperature? Do I just type in T(xo,yo,zo) or I need to define T first?
Zhenhuan Xu
Hello Zhenhuan Xu
