Henrik Sönnerlind
COMSOL Employee
2015/09/16 16:47 GMT-4
Yes, that is possible by using the setval() argument to withsol().
See for example the discussion in
www.comsol.com/community/forums/general/thread/86181
Henrik
See for example the discussion in http://www.comsol.com/community/forums/general/thread/86181
Henrik
2015/09/19 1:02 GMT-4
Thank you, Henrik. So, for a certain eigen value, it would be setval('solnum', ##)??
Henrik Sönnerlind
COMSOL Employee
2015/09/21 3:04 GMT-4
In your case it probably easiest to pick by eigenvalue number (rather than by value). Use setind() like in withsol('sol1',emw.normE,setind(lambda,2)) to pick eigenvalue number 2.
Trick: Use withsol() in a plot to see that it works as expected. With the expression above you can override the Data set and Mode index selectors in the plot.
Henrik
Henrik
2015/09/22 5:08 GMT-4
Thank you, Henrik, It works perfectly:) One final question: is there a way to do the same thing by defining variables in the variables section? I have checked that the "withsol" command works for the second set of solutions but not if I try to use the first set of solutions that is stored as Solution Store 1.
Henrik Sönnerlind
COMSOL Employee
2015/09/23 2:13 GMT-4
It should work under Variables too. Variables containing withsol() operators can of course not be used in a place in the solver sequence before the referenced solution is computed. But that should not be the issue here, since it seems to be the first solution (='sol2') which causes problems.
Please submit your model to support if you cannot sort out this problem.
Henrik
Henrik
2015/10/08 1:23 GMT-4
Thank you, Henrik. It works for my requirements!
